Sequencial Circuits Studio 440
HxC Floppy Emulator Sequential Prophet Keyboards support
Re: Sequencial Circuits Studio 440
Mix-club wrote:well after many tries i found out that you should use the A drive only .
i dont know if it really makes a difference but for sure the HXC will not load files above 2.00 mo otherwise this error message appear .
Yes the Studio 440 use DD floppies.
Fimage
Post by Fimage »
Mix-club wrote: Fri May 26, 2017 9:45 am well after many tries i found out that you should use the A drive only .
Hello Mix-club, Could you please tell exactly how you did setup the dip-switches as i have the same problem?
So far i am only able to save/load using this image provided by Lotharek; S-440-WaldKitFx1.hfe
Any other gives the error.
(i have updated the firmware and tried different dip switch settings,but no luck)
Thank you very much.
What are you trying to do ?
