osborne 1
h3rb
Re: osborne 1
Post by h3rb »
Can you talk about the SD card flashing process? I'm going to try to get this working with a Zorba 2000 but have no idea how to take a .Td0 (Teledisk image) and flash an SD card with it ...
See, the Zorba I have has no disks and I cannot find anyone willing to make me legit disks, so I'm hoping I can use this emulator to boot the darn thing with 1 real 1 emulated drive.
Anyone have any direction you could give me?
Re: osborne 1
h3rb wrote:Can you talk about the SD card flashing process? I'm going to try to get this working with a Zorba 2000 but have no idea how to take a .Td0 (Teledisk image) and flash an SD card with it ...
Use this to convert your td0 file :
number-one
Re: osborne 1
Post by number-one »
Hello I want to recreate floppy disk for my Osborne I computer (come without floppy)
I have a kryoflux with 5.25" PC floppy drive and some TD0 images
http://www.retroprograms.com/temp/Osborne_TD0_Disks.zip
I load OSB01_CPM_System.TD0 with HxCFloppyEmulator sofware but I can't export to IPF extension.
(no IPF file is created)
The export works with HFE extension but how write it on a floppy with my kryoflux ?
Re: osborne 1
number-one wrote: Wed Nov 28, 2018 5:00 pm Hello I want to recreate floppy disk for my Osborne I computer (come without floppy)
use the kryoflux stream export.
number-one
Re: osborne 1
Hello, a friend installed on my Osborne 1A an HXC floppy emulator for emulate the 2 floppy drive.
The computer read correctly the floppy HFE image on drive A and B.
But on write the HFE image crash.
number-one
Re: osborne 1
Where is the problem ?
Re: osborne 1
Which drive are you formatting ?
number-one
Re: osborne 1
HXC B from HXC A copy command
Re: osborne 1
number-one wrote: Sun Sep 01, 2019 6:07 pm HXC B from HXC A copy command
Can you share the formatted hfe ?
number-one
Re: osborne 1
oterm formatted.zip
(44.41 KiB) Downloaded 3145 times
Re: osborne 1
number-one wrote: Sun Sep 01, 2019 6:27 pm oterm formatted.zip
use this one instead.
blank_fm.zip
(5.61 KiB) Downloaded 3089 times
CloudInMyHead
Re: osborne 1
Post by CloudInMyHead »
Should these tips/instructions also work with the new Artery based microprocessor GoTeks?
number-one
Re: osborne 1
Jeff wrote: Sun Sep 01, 2019 9:46 pm
blank_fm.zip
Formatting floppy works now by cut the signal 34 of the ribbon.
I want to know if this floppy adapter of the url is working with the original HXC?
https://github.com/WayneVisser/Osborne1FloppyAdapter
Re: osborne 1
number-one wrote: Fri May 31, 2024 10:58 am
yes this should work without issue.
number-one
Re: osborne 1
Can I change the drive A or B setting directly on the HXC, without touch the jumper on gotek adapter PCB ?
