Write support for the Amiga (Firmware V1.3.0.0)
javidoom wrote:Cool!!!
You're the best. :)
Waitinngg ;)
https://hxc2001.com/floppy_drive_emulat ... _3_0_1.UPD
(bad id detection. here i didn't use the same model)
javidoom
Post by javidoom »
Wwwwoooorrrrrkkkkksssss!!!!!!!
Coool thanksss!!!
javidoom wrote:Wwwwoooorrrrrkkkkksssss!!!!!!!
Coool thanksss!!!
Excellent !!! :D
Thanks for your feedback this is very important !
So your are the very first person to test it (the version 1.3.0.0 didn't worked for the 23K256 ;-) )
For the moment the write routines are very slow and can be improved a lot (in fact many thing must be changed). Actually only a small part of this sram are used.
So actually fast disk copier like XCopy didn't works, but this will improved later.
Anyway Create/Write/delete/move files under Workbench are working well. (tested on A500 and A600)
:D
javidoom
Post by javidoom »
Lol!
You are wrong!! :)
Xcopy is working!!! I'm trying to upload a videi showing it right now :)
I'll post the link if i can in a few mins :)
Again, ThANKS!
javidoom wrote:Lol!
You are wrong!! :)
Again, ThANKS!
mmhhhh no, or maybe you have a very fast sdcard :roll:
javidoom
Post by javidoom »
Yes yes i swear
I'm posting from my phone and trying to upload the video...
My card is a lexar 8gb normal...
Edit!!!: Works if you copy VERIFING!
Don't work if you copy without veryfing.
In my video is working because i wrote veryfing the first time i tried, and the second without veryfing was on the d same disk...
But veryfing, seems it's a little slow and works :)
the videos:
http://www.youtube.com/watch?v=D2lHKQJgeeQ
http://www.youtube.com/watch?v=JOk4WCQDHx4
not much quality but it's enough i think...
And I've tested 3 times, and yes, I can copy veryfing, without, it's not working (/using XCOPY PRO).
In workbench works perfectly :)
THANKS!
javidoom wrote:Yes yes i swear
the videos:
THANKS!
With copy veryfing i am ok ! :D
emrezanbak
Post by emrezanbak »
emrezanbak wrote:Thanks Jeff.
http://www.commodore.gen.tr/forum/index ... ttach=2629[/img]
It's working for you too ?
To everyone: There are a SO8 version available of the sram. This make the modification almost invisible ;-)
emrezanbak
yes work. thanks Jeff.
I have updated the official firmware archive with the working version:
emrezanbak
my emulator upload file;
amiga read and writing ok. success rename file and folders.
emrezanbak wrote:my emulator upload file;
Yes this is the same :wink:
indianas
Write Support for Amiga?
Post by indianas »
I'am confused, i'am read on some sites thats not supported, and here are
it !
Re: Write Support for Amiga?
indianas wrote:I'am confused, i'am read on some sites thats not supported, and here are
it !
The HxC Floppy Emulator project is a project in constant evolution. There are new features, new computers supported, new file format supported at each firmware/software release.
So the only website to trust about this project is this one :
https://hxc2001.com/floppy_drive_emulator/
Others may contains bullshit, outdated informations or miss informations...
Yes the write support in now supported if you add a little chip to the actual board. The next batchs will contain this add-on.
EDIT : Where did you see that this is not supported ?
