Spectum and Sam
caver99 wrote:when i load the file as a a raw file adn the conver/save as and then copy the .hfe file to sd card and view it on the sam its empty but useing the .sad file in the sam emulator its fine.
could you send me this "sad" file ?
caver99
Post by caver99 »
yeh what e-mail address?
caver99 wrote:yeh what e-mail address?
This one :
caver99
Post by caver99 »
E-mail on its way to you.
caver99 wrote:E-mail on its way to you.
I didn't receive it !
caver99
Post by caver99 »
ooppss sent to wrong e-mail sending now
caver99 wrote:ooppss sent to wrong e-mail sending now
i received nothing.
caver99
Post by caver99 »
ok i will try again right now
caver99
Post by caver99 »
Sending now
caver99 wrote:Sending now
ok i got them.
So Prince of Persia.sad is in reality a SDF file type. I have send a mail to Simon Owen (the official author of this format) for more details.
Manic Miner.sad is a SAD file with a header of 22 bytes (in fact this is a true SAD file -> 819222bytes) others sad files extension with a size of 819200bytes are in the MGT file format.
I need some details about this header.
caver99
Post by caver99 »
OK.
thats good you finaly got them.
caver99 wrote:OK.
I got an answer from Simon Owen:
Hi Jean-François,
SDF was a temporary format I created for SAM Coupé disk images, before switching to EDSK (as also used for +3/CPC disks). Lemmings and Prince of Persia were the only 2 images ever publicly released in SDF format, and the Lemmings dump was later found to be missing a track! Both have since been re-dumped in EDSK format, and I've been hoping the SDF images would be forgotten. Unfortunately the TOSEC/Good collections make that difficult!
There are no public tools to create SDF images, and I'll be removing SDF support in the next release of SimCoupe (the SAM Coupé emulator), so I'd recommend you ignore it too. If you'd still like to know the details I'll dig them out for you.
So i will drop the SDF format. You should be able to found the EDSK version of Prince of persia (The software already support the EDSK).
For the SAD &MGT format i have just send to you a beta version of the software. "Manic Miner.sad" should works now.
I am waiting your feedback.
caver99
Post by caver99 »
Sorry but at the moment my e-mail is down but you can send to my works address which is graham.prout(at)cdk(dot)co(dot)uk and i will take it home.
caver99
Post by caver99 »
I have been useing the one you sent me now and it work great.
Thank You.
