Errors reading disks converted from Kyroflux RAW to HFE (re: BAD CRC)
sofakng
Re: Errors reading disks converted from Kyroflux RAW to HFE (re: BAD CRC)
Post by sofakng »
That seems to work! The volume label is garbage/corrupt, but the game works!
How did you create the file?
sofakng wrote: Thu Jun 24, 2021 9:00 pm That seems to work! The volume label is garbage/corrupt, but the game works!
I have just fixed the bitrate to 250kbits/s on all the tracks to remove all the dump drive motor noises (probably not needed), set the interface mode to ibm pc dd, then i have exported the image to hfev3.
