cant add this files because of resctrictions. they are the standard images which was included in one of the files from this site.
And the problem is if there is no stick in the emulator the Sampler does not boot. So i think it has to do something with the drive, with the firmware or the jumper settings. Or do you have an idea what could be the problem?
Casio FZ 10m problems with Gotek
ghostinthemachine
ghostinthemachine
Re: Casio FZ 10m problems with Gotek
Do you know other users who got this working on an FZ10m?
Jeff_HxC2001
Sure there is a lots of user using it on the Casio FZ1/FZ10m. I suspect that you have an hardware problem (the disk change signal sticked to the disk present state). You should run the dignostic firmware to test this signal.ghostinthemachine wrote: Thu Aug 15, 2019 3:25 pm Do you know other users who got this working on an FZ10m?
ghostinthemachine
which diagnostics do you mean?
Have a look to the firmware archive :
in "Diagnostic_Firmware".
-----------H----H--X----X-----CCCCC-----22222----0000-----0000-----11----------
----------H----H----X-X-----C--------------2---0----0---0----0---1-1-----------
---------HHHHHH-----X------C----------22222---0----0---0----0-----1------------
--------H----H----X--X----C----------2-------0----0---0----0-----1-------------
-------H----H---X-----X---CCCCC-----22222----0000-----0000----11111------------
-- Contact: hxc2001<at>hxc2001.com --------------------- https://hxc2001.com --
HxC Floppy Emulator project
(c) 2006-2019 Jean-François DEL NERO / (c) HxC2001
Forum : http://hxc2001.com/floppy/forum
Facebook : https://www.facebook.com/groups/hxc2001
Store : https://hxc2001.com/store/
- Gotek I/O Lines Diagnostic/Test firmware
Since this hardware is quite sensitive to ESD and other electrical issues, the floppy lines can be easily damaged.
This firmware allows you to test/check all Gotek's Input/Output lines with a simple wire.
The test must be run with floppy ribbon disconnected from the machine.
Once enabled/flashed with the diagnostic firmware, all outputs will toggle every 2 seconds.
All inputs states are displayed on the screen.
-> Input lines test method :
The default input states should be High (1), so to test an input line you have just to connect it
to the ground/vss. On the floppy port you just need a jumper to make a contact between the line and the ground.
Once the jumper is placed between the line pin and the ground/vss pin the corresping input state should turn to Low (0).
-> Output lines test method :
All outputs are toggling every 2 seconds during the test.
(Note : A 1 ms pulse is sent to the JB output at each toggle to test the buzzer ouput)
Connect the output line to test to one input line (use a tested input by the above method) with a simple wire.
If the corresponding input status is toggling with the outputs line, then this means that the output line/driver is working properly.
-> LCD / OLED / 7 segments screens output/input status definition :
LCD/OLED input lines status format : "IN:123456 789AB"
1 or Digit-1-segment-a : Floppy Drive Select line (Pin 10 or 12 or 16 -> Depend on the S0/S1/MO jumper !).
2 or Digit-1-segment-b : Floppy -Direction In (Pin 18)
3 or Digit-1-segment-c : Floppy -Step (Pin 20)
4 or Digit-1-segment-d : Floppy -Write Data (Pin 22)
5 or Digit-1-segment-e : Floppy -Write Enable (Pin 24)
6 or Digit-1-segment-f : Floppy -Head 1 Select (Pin 32)
7 or Digit-1-segment-g : Down push button (left)
8 or Digit-2-segment-a : Up push button (right)
9 or Digit-2-segment-b : Select push button (JA)
A or Digit-2-segment-c : Rotary CK (J7-2)
B or Digit-2-segment-d : Rotary DIR (J7-1)
7 Segments Digit-3 : 'h' when the outputs are high and 'L' the outputs are low.
7 Segments Digit-2-segments e,f & g : ON when the outputs are high and OFF the outputs are low.
-> Floppy connector pinout :
Pin Signal Pin Signal
01 Ground (O)02 -High Density Select
03 Ground 04 Reserved
05 Ground 06 Reserved
07 Ground (O)08 -Index
09 Ground (I)10 -Drive Select 0 (*)
11 Ground (I)12 -Drive Select 1 (*)
13 Ground 14 Reserved
15 Ground (I)16 -Motor Enable (*)
17 Ground (I)18 -Direction In
19 Ground (I)20 -Step
21 Ground (I)22 -Write Data
23 Ground (I)24 -Write Enable
25 Ground (O)26 -Track 0
27 Ground (O)28 -Write Protect
29 Ground (O)30 -Read Data
31 Ground (I)32 -Head 1 Select
33 Ground (O)34 -Diskette Change/Ready
(*)Depend on the S0/S1/MO jumper!
-> 7 segments screen segments definition :
// a
// f b
// g
// e c
// d
ghostinthemachine
can you please explain how to do this test?
This is explained in the above post.
The signal you want to test is the pin 34.
ghostinthemachine
I tested the Gotek and everything is ok. I also used another Gotek and the same Problem.
Any other Ideas?
Any other Ideas?
You should have received an new firmware in your email box. Update to it and tell me if this help or not.ghostinthemachine wrote: Tue Nov 12, 2019 5:17 pm I tested the Gotek and everything is ok. I also used another Gotek and the same Problem.
Any other Ideas?
