Emax Config Autoboot files etc...
Re: Emax Config Autoboot files etc...
Kna wrote: Wed Jan 17, 2018 6:48 pm Great, it worked!
Have now upgraded to SE1.1 and the factory library loads beautifully.
Thank you so much Jeff!
Now, some last questions, just for the sake of understanding:
In the SD config-file setup:
What is indexed mode?
What is the interface setting "Mode (From HFE)" ?
Why do the config-file apparently reset itself?
Don't use the indexed mode. this mode is usefull with hxc devices without lcd.
interface setting "Mode (From HFE)" means that the emulator will use the mode specified into the hfe file.
i don't understand. what do you mean by "reset itself".
Kna
Post by Kna »
By "resetting itself" i meant that the config-file loads with the HFE file interface-mode set to auto even if i try to save the config-file with generic Shugart. Probably not important, as it works, but difficult to grasp the meaning of. :-)
