Ensoniq EPS 16 +
lowcust
Re: HxC SD Card Emulator on Ensoniq EPS16+
Post by lowcust »
lowcust wrote:first test with the SDCard HxC Floppy Emulator on my old Ensoniq EPS16+ sampler. works great!
http://www.youtube.com/watch?v=r09ZJPwi3eU
Thanks for your feedback ! :D
hi jeff
I have a little problem that recognizes Ensoniq if not the virtual floppy is changed. I can work around the problem only if I break the 5volt circuit, and thus recognizes new floppy to able to load.
My question would be whether perhaps be simulated by software or firmware?
thx, best regards
hi jeff
thx, best regards
Try to change the interface mode in the "Settings" before export/convert hfe files. Try the Mode "IBM PC 1.44MB" or "IBM PC 720KB"
(Note : a small software update "1.3.9.1" that correct a "bug" in the convert function : https://hxc2001.com/floppy_drive_emulat ... r_soft.zip )
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: Thanks for your feedback ! :D
hi jeff
thx, best regards
hi jeff
little problem, i made the firmwareupdate to 1.3.0.0 and hxcsoftwareupdates and now some images of my ede. files will not work, the first boot/system ede.hfe file of my ensoniq works but than the ensoniq does not recognize exchanged ede.hfe files. a backup from my old files with amaiga/atari settings will work, some time he recognizes but also no change from hfe files, what i was doing wrong.
ps: one please, it would be nice when the efe. format "samples" are supportet.
thanks in advance, best regards
lowcust wrote:
lowcust wrote: hi jeff
thx, best regards
hi jeff
What was your previous firmware version ?
Your old hfe files are working ?
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: Try to change the interface mode in the "Settings" before export/convert hfe files. Try the Mode "IBM PC 1.44MB" or "IBM PC 720KB"
hi jeff
my old firmware was 1.1.1.0, yes my old hfe files are working ,but unfortunately the ensoniq recognized rarey diskchanges.
So send me your old hfe and the corresponding ede please.
new hfe didn't works ?
For the diskchange try this :
to change a disk -> eject the actual floppy disk -> wait 4 seconds -> then insert the new one.
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: Hi,
hi
new hfe files don´t work only EPSOS130_EDE.hfe works with almost every setting.
http://www.beitegeuze.com/hfe.rar
thank you, best regards thomas
hi
can you send me the ede file please ?
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: So send me your old hfe and the corresponding ede please.
hi
I've added today some of the ede. files to the hfe.rar archiv.
Can try this software version to convert your ede files ?:
And for the disk change problem can you try this ? :
lowcust
Post by lowcust »
Jeff wrote:Hi,
hello
unfortunately it does not work, but with preferences setting "amigaHD DS0" he recognizes all files and diskchanges but it do not load the files it brings the error message. but I think we are on the right path :)
http://www.ensoniqsamplers.com/epsasr/022.html
"The EPS/VFX/SD series of instruments use the "Shugart" type and is not made anymore. Right now many people are having their floppy drives break, only to have no recourse on replacement parts, even from Ensoniq."
shutgart settings work unfortunately not, perhaps is that the error?
thank you and a nice weekend, thomas
lowcust wrote: hello
Who is "He" ? the emulator or the keyboard ?
What is this error message ?
lowcust
Post by lowcust »
sorry for my english, i mean the the ensoniq. he loads the bootdisk and wboy.ede filedir. but not the complete files than he brings the errormassage "disk can not be load". the ensoniq is a diva on handling with floppydrives.
Can you try this firmware ? :
https://hxc2001.com/floppy_drive_emulat ... 3_0_2b.UPD
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: Who is "He" ? the emulator or the keyboard ?
hi jeff
good news, it works. now with shutgart ds0 setting, the ensoniq recognizes all files on disk and load than, also diskchanges now working trouble free. i'm still tests whether funktions like format,copy and save will work.
if it allows your time, it would be cool if the ensoniqs efe. format import would still work, efe. is only for samples like wav. on windows but ede. for complete programs which means samples, effects and songs include configurations.
thank you very much, thomas
