TRS-80 Model 1 and the HXC SD FW Floppy Drive Emulator
Audronic
Re: TRS-80 Model 1 and the HXC SD FW Floppy Drive Emulator
Post by Audronic »
Hi Jeff
"" In this case you have just to set the pin 34 to HIGH into the embedded HxC menu.""
The Ready signal is not used.
I have cut the Link between 32 and 34 (not Needed)
How do I get into the Embedded HxC Menu Please. Is there documentation i have missed.
or the Name of the documentation Please.
Thanks again
Yours Ray
If it ain't Broke then PLEASE DONT fix it.
Procrastinators Unite !
Audronic wrote:Hi Jeff
Thanks again
Yours Ray
Just remove the SD and press select -> Interface cfg -> custom -> select the pin 02 & pin 34 behavior.
Audronic
Post by Audronic »
Hi Jeff
Thanks for the Setup info, I will use it if i get stuck again.
Yours Ray
