Korg T3ex problem
cdtmbu
Re: Korg T3ex problem
Post by cdtmbu »
Thanks ! :D
We have now a perfect bit per bit image of the T3 disk format !
Can you take some pictures and videos of the HxC in the T3ex ?
Which jumper setting is used ?
The pleasure is on my side.
I will do some pictures. I have not used any setting just disabled the disk drive selektor in the cfg file.
cdtmbu
Post by cdtmbu »
Sent the pictures to you.
replace the dll by the one present in your email box.
and use the "Korg T3 3"5" predefined disk layout.
you can use the batch converter too.
Let me know how this works...
And spread the word :)
cdtmbu
Post by cdtmbu »
It seems to work. I can read now at least one of the converted images. I will try the rest the next days.
Thanks for your support.
jhulk
Post by jhulk »
hi jeff i have omniflop img of the t3ex if you require it let me know and i can send them to you
also im just about to fit a revf to a 01w i also do the images in omniflop img format if you require them also
as i also do my ensoniq sd1 sq80 in omniflop img format
cdtmbu
Post by cdtmbu »
one short question: in the email I sent to you were 2 files: PCM.hfe and Prog.hfe. These are formatted in a different way. The Prog does contain 4 possible savings without PCM data and the PCM contains only one saving including the PCM data. Do we need two different hfe file versions for the T3ex?
Regards,
Chris
cdtmbu
Post by cdtmbu »
Everythink is working in respect to the T3ex data. But I do have some problems concerning conversion of DSM-1 PCM disks. The images are created with copyqm as far as I know. They can be found at the following site:
http://www.wiseguysynth.com/larry/dsm-1/disk-dsm.htm
Do you also have an algorithm to change them to hfe files?
Regards,
Chris
Just drag&drop the image on the main window : CopyQM images are directly supported by the HxC Software.
cdtmbu
Post by cdtmbu »
Tried again and worked!
Chris
monolight77
Post by monolight77 »
Hello Jeff and Chris.
Wish you could share that pcm.hfe file.
Feder
Soundbytes
Post by Soundbytes »
Hi I have owned a Korg t3ex from new. I’ve got the dreaded data error problem and none of my disks will load. I bought a new drive off eBay and even tried to format new high density disks with no success. I’d hate to lose all my sounds and samples collected over 25 years so if anyone can help me fix this I’d be over the moon. The thought of losing all my old band sounds is killing me. Is something like omniflop and an cf card reader the answer in which case can someone send me the 2 image files I need ( one being for pcm/programs one partition and the other for programs/combis, sequences/ 4 partitions. Please please help. soundbytes@ntlworld.com
Stephen.
Andre
Post by Andre »
Hi Stephen
Did you manage to save your sounds at all? I have a T3Ex and am new to sysex and midi dump. Could you transfer your sounds that way at all? I'm not sure how to do it. I was reading a lot from this site too:
https://jimatwood.wordpress.com/2011/09 ... ment-15288
Hope it helps,
Andre
Have you a floppy emulator ? Which one ? And what is the firmware version you are using ?
darq82
Post by darq82 »
Hi everyone,
I would like to connect to the topic becasue I have just installed HXC Gotek in Korg T3 and the instrument freezes when trying to read and format a floppy disk.
The firmware version is HxCFEUSB_V3_5_2_5a
I tried to use cfg file from 'Quick install floppies' - SDHxCFE_PC_1.44MB
Disks dumps https://drive.google.com/drive/folders/ ... sp=sharing
Thank you,
Regards,
Darek
Try to generate a new firmware with the "Non gated mode" option set :
