SDHxC to emulate a IBM3740 Format?
Frank
Re: SDHxC to emulate a IBM3740 Format?
Post by Frank »
Thanks Jeff,
Frank wrote: Is there a way to convert the *.imd files to a *.raw file?
Jeff wrote: yes : export them the img file format.
yes, over this longer way the BigBoard 1 is booting CP/M. :D
I think, the characteristics in the original BB1.IMD are not identical with the right settings.
Frank
Frank wrote:Thanks Jeff,
Frank
What is the right settings ?
Frank
Post by Frank »
these are the settings, which are working currently.
Frank
PS: is there a way to modify the data value for the empty sectors when "Create empty floppy"?
Frank wrote: PS: is there a way to modify the data value for the empty sectors when "Create empty floppy"?
Yes : Format Value.
(note : i recommend you to use the v2.6.0.0 software.)
Frank wrote:Hi Jeff,
Frank
i don't see the difference between this and the imd settings.
Can you send me your non-working HFE file converted from imd and the working imd file ?
Frank
Post by Frank »
At the moment i can't also no differences between the direct and the indirect (over RAW-data) way.
Both work and boot. :?
Frank
PS: At first i don't understand the viewing window in your "visual floppy disk". I have to select the track before i can see the contents. :roll:
Frank wrote: Both work and boot. :?
So all is fine ?
Frank
Post by Frank »
Thank you Jeff,
now is all fine.
Frank
Frank wrote:Thank you Jeff,
now is all fine.
Frank
Some pictures maybe ?
:wink:
Frank
Post by Frank »
Sure Jeff,
here they are. :D
Frank
Frank
Post by Frank »
and so on.
