Yes we really need a real qd drive to compare with itAMSynths wrote: Tue Aug 27, 2019 12:40 pm Looking at the 5 second trace, the first write cycle is taking longer than 5 seconds and the ready off cuts the data off. Looks like it takes 5.2 seconds to check disk and then write the data.
2.8" QD Disk Emulation
Jeff_HxC2001
Re: 2.8" QD Disk Emulation
Jeff_HxC2001
Idea : can you try to record/load a sample into the machine and save it to the qd files ? I will try to extract the sample to a wave file.
I have started testing on a S220 with a working QD. The first thing to note is that the "normal" save cycle has three stages. A read of the disk to see if its empty or not, the whole disk is read rather than just the initial "header", then a write cycle and then a read cycle to verify the data.
A fast F1 save, skips the first read of the disk and has the write followed by the read.
Both types of save fail on verification. I will trace the real QD now
- Fast Save to HxC Read and Ready signals
- Fast Save - Read and Ready.jpg (52.26 KiB) Viewed 49917 times
About this screen, can you show me the write gate signal ? there is maybe a pre-erase write part before the data output, this maybe important to know (write gate + write data trace)AMSynths wrote: Tue Aug 27, 2019 12:40 pm Looking at the 5 second trace, the first write cycle is taking longer than 5 seconds and the ready off cuts the data off. Looks like it takes 5.2 seconds to check disk and then write the data.
Read QD, Fast Save and then a Load
- Load - Ready and Read Data
- RealQD - Read Cycle.jpg (51.06 KiB) Viewed 49916 times
- Fast Save - Ready and Write Data
- RealQD - Write Cycle.jpg (51.26 KiB) Viewed 49916 times
- can you do the same capture with the write gate instead of write data ?
- What is the exact ready signal assertion time ?
Write Gate and Write Data trace is attached.
Ready assertion time is 4.5 seconds during the write and 4.5 seconds for the read verification.
All on Fast Saves - no checking of the disk first.
- Fast Save- Write & Write Gate
- Fast Save - Write & Write Gate.jpg (50.6 KiB) Viewed 49912 times
Wait ! I see two glitches on the write gate at the beginning ?! Is it real ? Can you zoom them ?AMSynths wrote: Tue Aug 27, 2019 2:43 pm Write Gate and Write Data trace is attached.
Solo Syn.4 saved to these files. Bank D.
- DSKA0000.zip
- (216.55 KiB) Downloaded 5323 times
I see two glitches on the write gate at the beginning on your last capture ?! Is it real ? Can you zoom them ?
here is the detail of the Write Gate glitch, it happens maybe 1 in 4 times, not every time.
its not me moving the probes..
- Detail
- RealQD - Write Gate Glitch Detail.jpg (75.01 KiB) Viewed 49908 times
- Real QD Write Gate Glitch
- RealQD - Write Gate Glitch.jpg (70.6 KiB) Viewed 49908 times
This can definitively disturb the software. now i suspect that main header is not recorded (lost) i have to check if the wg filter is enabled and if it is "strong" enough.AMSynths wrote: Tue Aug 27, 2019 3:55 pm here is the detail of the Write Gate glitch, it happens maybe 1 in 4 times, not every time.
I have increased the WG filter value. Try this to write to a blank 4.5 seconds QD image with the attached fw, if possible with a sample loaded into the memory. (Not tested, may fail dramaticallyJeff wrote: Tue Aug 27, 2019 4:10 pmThis can definitively disturb the software. now i suspect that main header is not recorded (lost) i have to check if the wg filter is enabled and if it is "strong" enough.AMSynths wrote: Tue Aug 27, 2019 3:55 pm here is the detail of the Write Gate glitch, it happens maybe 1 in 4 times, not every time.
Does not work, verify error. Sorry...Real sample bank loaded from QD then saved to HxC
Please share the image.
