Edge Card to 34 Pin Connector for HxC?
dykesh
Post by dykesh »
I have an early Emulator II with one 5.25 Floppy Drive. Inside there are additional connectors for a second drive with one 4 pin molex for power and a edge card connector for another floppy drive. I've got a 4 pin molex adapter for the HxC but I cannot find anything on the internet to adapt the edge card to a 34 pin header? I think I could manually change out the edge card with a 34 pin header but I would rather find an adapter or some other option. Could anyone tell me what your doing with this? thanks
Re: Edge Card to 34 Pin Connector for HxC?
dykesh wrote:I have an early Emulator II with one 5.25 Floppy Drive. Inside there are additional connectors for a second drive with one 4 pin molex for power and a edge card connector for another floppy drive. I've got a 4 pin molex adapter for the HxC but I cannot find anything on the internet to adapt the edge card to a 34 pin header? I think I could manually change out the edge card with a 34 pin header but I would rather find an adapter or some other option. Could anyone tell me what your doing with this? thanks
Try to find old PC floppy cable with the edge connector.
other solution : try get an edge connector in your local electronic store and add it to an normal floppy cable.
Example :
http://fr.farnell.com/avx-interconnect/ ... /dp/635807
dykesh
Post by dykesh »
I found this to buy and try if it helps anyone else. I think it will replace the cable that's in there.
http://www.startech.com/Cables/Drive/ID ... Cable~FDAT
Thanks for the help.
