Hi All,
I was wondering if there was a way where you could possibly share drives between an internal drive & the HxC?
What I mean is, is there a way say on my Amstrad CPC 6128 that I can fit a switch that swaps the power between my original drive in the machine & the HxC. Also get a ribbon that I could connect to both drives at the same time.
I have loads of original games that I cannot play anymore as it all geared up toward the HxC which is a shame.
Could this be done?
Share Floppy Drives?
pulkomandy
Re: Share Floppy Drives?
Not with the power supply only.
You need to somehow swap the drive select lines.
