Hi Jeff and Hi all,
I've tried to change via the device buttons slots on the emulated drive DF1: but without any success. When pressing the change button only the drive A (DF0:) mounted slots are showing on the device LCD screen - (sorry - i didn't add the last sentence and maybe i wasn't clear enough) - how to change slots mounted on the second drive - Drive B (DF1:) using the device (hardware) buttons. As you can juggle with slots one drive A, there's no possibility to jump to another slots on drive B (DF1:). Maybe I'm missing something anyway any help will be appreciated.
Thanks in advance,
Diskers.
Slots on drive B (DF1:)
wallmaker84
Re: Slots on drive B (DF1:)
I have the same problem...I don't understand how to select HFE images on slots dedicated to B (DF1) emulated disk...
Any help is appreciated....
Daniele - Amiga Italian Fanatic
pulkomandy
Press the middle button for 1 or 2 seconds to get to a menu where you can select drive B.
wallmaker84
Thanks i will try and keep you updated...
Daniele
Daniele
