How to insert the Emulator like on this picture?
NBG
Post by NBG »
how can i insert the Emulator like on this picture?
The insert of the disc is on the floppy side... but the display and the knobs are on the front panel.
I know that the display is removable... but is it easy to put it anywhere on the amiga with a "extension cable"?
Also how did he put the knobs on the front?
NBG
lotharek
Re: How to insert the Emulator like on this picture?
Post by lotharek »
it takes hell of a lot of work..
one mistake and looks shitlike.
i do sth like this - chec my other posts. it takes week - 4 weeks depends of cnc machines service supplier.
ps. check info of sd hxc - you have there info about external panel pinout - j2 connector
..... Atari Roxxx !!!
endre1952
Post by endre1952 »
I use a soldering iron to modify (melt out) the case. It's a crude method, but in the end, the solution is good enough for me.
