Question about IPF to HFE conversion
ivathoma
Post by ivathoma »
I was wondering if you could help me with converting IPF images to HFE using your HxC SD Emulator Software?
I need to do this to be able to install games with WHDLoad.
For some reason I can't get the RawDIC working (only DIC), thus I need to have the images present on the floppy emulator instead of just having them on the harddrive.
Any chance you could help?
Ivar.
Re: Question about IPF to HFE conversion
ivathoma wrote:Hi,
What's the problem exactly ?
ivathoma
Post by ivathoma »
If I try to use the batch converter on IPF files I get a message saying "0 files converted".
By dragging and dropping an IPF file in the software window I get a message saying "unsupported filetype".
I've tried to load IPF-files and exporting them as HFE as well, but they can't be recognized in WB then.
Is there a certain way to do this?
ivathoma wrote:If I try to use the batch converter on IPF files I get a message saying "0 files converted".
ok. Due to a License issue i had to remove the caps dll from the website.
So you have get the caps dll yourself on the sps website :
http://www.softpres.org/download
ivathoma
Post by ivathoma »
Thanks a lot for your swift response! :)
Should I just place the dll in the same directory as the SD card emulator software?
Edit:
Nevermind that last question. It works when I have the dll in the same dir.
Thanks a million for your help. Most appreciated! :)
Ivar.
