Sharp MZ 800 Quick disk
ales
Post by ales »
Hi all,
I would like to ask for QD firmware and QD image (with something on it) which combination is confirmed to work with Sharp MZ 800 QD interface.
I cant format QD image at all with "no file space error".
Reading looks working with Ok! or "unformatted" error what is logical if I cant format the image.
Need to test with your working image/firmware if there is another problem in my intergace.
I have SFR1M44-U100LQD model.
Thank you in forward for the help.
Re: Sharp MZ 800 Quick disk
ales wrote: Fri Jan 23, 2026 7:11 pm Hi all,
So reading is working ? Which image are you trying ?
Which firmware are you using ? What is displayed on the screen ?
ales
Post by ales »
Im using the last build and tried all the QD images from your package. Also tried custom builds with different parameters for QD version.
Not sure if reading is really OK, because I have no QD with files for Sharp, but reading shows no error.
When formating, display shows R and three times W access. Sharp then shows "No file space error". Reading (DIR) then shows OK! or "unformatted error" alternatively.
Write protect and disk ready signal works OK as Sharp react on them accordingly.
Wiring checked hundred times :-)
Have no buzzer connected on jumpers.
please share the hfe before and after the write attempt.
btw which gotek have you exactly ? An at32f415 based gotek or something else ?
if possible try the HxCFEUSB_V3_4_11_2a_QuickDisk.UPD firmware.
ales
Post by ales »
Im using the QD image included in the package. Dont know how to generate HFE format for quickdisk.
I have Gotek SFRM44-U100LQD-435 with AT32F435, confirmed by HW info menu.
To be sure there is no HW issue with the Gotek I have tested as FDD emulation on the same Sharp and this works OK.
Were there any confirmed Sharp MZ 800 user of the quickdisk emulation with HxC?
ales wrote: Wed Jan 28, 2026 10:55 am Hi,
I think that the last time i got a feedbacks about the mz-800 this was before the covid crisis, and for sure the AT32F435 goteks didn't even exist .
So it is very possible that a quirk/bug was introduced with the AT32F435 support...
Anyway please find attached a firmware with the right settings for this machine.
EDIT : Firmware Removed, see further posts
And also a qd file, converted from a qdf file (SPARROW (1984-12)(Henohenohe-Taro)(JP)[Micom BASIC].qdf)
The converter is very new, but hopefully you should be able to read/run it...
DSKA0000.QD.zip
(4.77 KiB) Downloaded 2351 times
Once the reading is working i will add the other MZ qd file format support.
(https://github.com/jfdelnero/HXCFE_QuickDisk_Toolkit)
HxCUSBFE.zip
(70.52 KiB) Downloaded 2460 times
I have just fixed something in the conversion, so this one has more chance to work :wink:
DSKA0001.QD.zip
(4.76 KiB) Downloaded 2361 times
ales
Post by ales »
thank you for sending the files.
I have tried to read your file
DSKA0001.ZIP
YourOriginalJustReadOnce
(5.11 KiB) Downloaded 2364 times
and Sharp showed "hard. error"
When I tried to format the file, Sharp showed "filespace error", but when read again it showed "Ok!" and no data on disk (which is logical after format). The file after format is
DSKA0001Format.zip
FormatedAndReadOnce
(496 Bytes) Downloaded 2344 times
Im using the FW you have sent me, jumper on MO and left SO jumper on from previous testing.
EDIT: when trying to boot from QD, Gotek freezes - LED still ON and display freezed (font skewed in the moment of scrolling)
ales wrote: Fri Jan 30, 2026 6:16 pm EDIT: when trying to boot from QD, Gotek freezes - LED still ON and display freezed (font skewed in the moment of scrolling)
mhh this is odd, i will this test the firmware on the QD machine i have here.. (An Thomson MO5 with the QD interface.)
Have you the same issues with the default firmware ? :
(the HxCFEUSB_V5_2_3_1a_Roland_QuickDisk_U100LQD.UPD firmware)
Do you know where i can find QD disks images for this machine (or MZ 700 / MZ 1500) ? i am interested by the lowest level file format (QDF, VirtuaQD images, QDC RAW/MFM ...)
Have you an logic analyzer to capture the data from a real quickdisk ?
ales
Post by ales »
I think that freezing during booting occured before, but was not so obvious as the display didnt show skewed font (did not freeze at the time of oled update).
I have logic analyzer, but havent used before, so first I have to get used to it and learn how to get the right data.
A soon as I have some hours to test I will come back hopefully with grabbed communication data from the analyzer.
Just for info, I have used STM32 gotek with Flashfloppy and it always freezes when accessing the QD. Your FW looks like step forward as it at least access the QD (Roland image shows "some" nonsense file names, clearly different format).
ales
Post by ales »
I have tried FW you have sent me and standard FW. Used the image you have sent me and one Roland image from standard package.
I used logic analyzer (Gusman LA open source) at 10kHz sample rate to be able to sample more second as some operations took long time.
Could you please check if it help to find the problem with QD?
Explanation of what test was performed is the name of data files.
Thank you.
LAQD_2.zip
Logic analyzer data 2
(162.02 KiB) Downloaded 2432 times
LAQD_1.zip
Logic analyzer data 1
(214.95 KiB) Downloaded 2446 times
Thanks !
Please find attached some good images. Please try to read them with both firmwares (the one from the official archive, and the one provided here) :
MZQD.zip
(105.22 KiB) Downloaded 2418 times
ales
Post by ales »
thank you for images.
But Im desperate... Reading shows unformat error, format shows filespace error, after format reading shows OK.
I tried officialnand FW fromnthis thread.
ales wrote: Sat Feb 14, 2026 7:22 pm Hi,
Please share the "OK" HFE.
To be sure i have reconnected the only QD machine i have here (an Thomson MO5 with the QDD extension) and tried the firmwares : You are right, i have broken something in the "roland" QD variant firmwares. Let me fix this and stay tuned ! :)
