MPC2000XL compatibility
ZEBS
Post by ZEBS »
I tried installing a HxC Gotek into an MPC2000XL but kept getting 'no floppy device !!' message.
Jumper setting was S0. I checked that the cable was connected correctly and also tried reversing the cable.
I used the Quickinstall files for MPC2000 as I couldn't see any specifically for the 2000XL.
Is HxC compatible with the XL?
Re: MPC2000XL compatibility
ZEBS wrote: Tue Oct 14, 2025 11:16 pm I tried installing a HxC Gotek into an MPC2000XL but kept getting 'no floppy device !!' message.
HxC emulators are compatible with MPC2000XL. But you need to change the interface mode to PC HD mode.
Or try these images :
https://hxc2001.com/download/floppy_dri ... PC_1M44.7z
