Issue Mounting HFE Image in DosDiskBrowser – Error Message
voronpap
Post by voronpap »
Hello everyone,
I’m currently using a Gotek SFRKC30AT3 device, which I’ve successfully flashed and configured with the community firmware. The Gotek is connected to a ZSK MSCD embroidery machine.
Thanks to this forum, I was able to find an HFE image file that is correctly recognized by the ZSK machine. However, I’ve run into an issue: when I try to open this HFE file using DosDiskBrowser, I get the following error:
"Some Errors found during the Image mounting! DOS Disk? Disk damaged?"
Has anyone experienced this issue before? Is there a known fix or workaround for opening this type of file in DosDiskBrowser?
Any help would be greatly appreciated!
