Windows 11 Problem?
toml_12953
Windows 11 Problem?
Post by toml_12953 »
I just updated my computer to Windows 11 24H2, OS Build 26120.2122. My HxC FLoppy Emulator installation no longer works. All it does is shows a very brief spinning circle then that disappears and nothing more happens. When I try to run it as Administrator, it doesn't even ask for credentials. I've tried both 32- and 64-bit versions. Both do the same thing. Does anyone else have this problem with Windows 11?
Re: Windows 11 Problem?
toml_12953 wrote: Fri Oct 18, 2024 7:38 am I just updated my computer to Windows 11 24H2, OS Build 26120.2122. My HxC FLoppy Emulator installation no longer works. All it does is shows a very brief spinning circle then that disappears and nothing more happens. When I try to run it as Administrator, it doesn't even ask for credentials. I've tried both 32- and 64-bit versions. Both do the same thing. Does anyone else have this problem with Windows 11?
which hxc version are you using ?
toml_12953
Jeff wrote: Fri Oct 18, 2024 8:42 am
I'm using (or trying to use) v2.15.1.2
toml_12953
Good news! MS updated the preview version of Win 11 today. It seems to have fixed the problem of HxC not starting. I do get a smart screen warning when I click on it but at least it runs.
toml_12953 wrote: Fri Oct 18, 2024 9:08 am
v2.15.1.2 is outdated.
