I have an AMSTRAD PC 5286. All the AMSTRAD 5000's PC series has a 1'44 MB CiTIZEN Floppy disk, model UIDA-38A (The exact model can change, but in my case is that). That floppy disk drive has a 26 pins connexion, and this is broken. To find another floppy drive with 26 pins that works, is very hard and expensive. I purchased an 26 PINS TO 34 PINS adapter from ALIEXPRESS to try to solve this problem (the same for all the AMSTRAD 5000 Series).
Link here:
https://es.aliexpress.com/item/10050036 ... pt=glo2esp
I have also a 7 segments digit GOTEK, model SFRKC30.AT3 (from amigastore.eu). I have purchased that in a second hand web, with the standard pins connections for AMIGA and PC (JC connected, S1 connected)
Initially, the GOTEK works fine. But cannot detect the disk change, with which is impossible to install directly any program with more of one disk. I can force the disk change in MS-DOS (Norton Commander, by example), but when the installation program is an .EXE or something, I don't have any physical mode to force the disk change, and the program installation fails.
The same thing happens with a traditional 3'5'' floppy drive that I've tried. I've been looking at the wiring diagrams on the internet, I've tried to connect some pins at the adaptor, but I haven't been able to do anything. I don't really know what I'm doing and if I'm doing it right either he-he
Can someone please help me to configure the adapter (or the GOTEK instead) so that the disk change detection works with the 26 to 34 pins adaption in the AMSTRAD 5286? I don't know if this happens in others PC systems...
Thank you very much!!
