hxc2001sd and adf files
elpiloto
Post by elpiloto »
hi there, is there any way to use adf on the sdhxc floppy emulator without the need of prior adf to hfe conversion? i mean using adf directly like the gotek
cheers
kiricowell
Re: hxc2001sd and adf files
Post by kiricowell »
elpiloto wrote: Tue Apr 02, 2024 6:07 am hi there, is there any way to use adf on the sdhxc floppy emulator without the need of prior adf to hfe conversion? i mean using adf directly like the gotek
cheers
To use ADF images with the SDHXC Floppy Emulator, you would need to convert them to the HFE format first. There are several tools available for this purpose, such as HxCFloppyEmulator (Windows), ADFLib (cross-platform), or other conversion utilities.
kiricowell wrote: Thu May 23, 2024 6:33 am To use ADF images with the SDHXC Floppy Emulator, you would need to convert them to the HFE format first. There are several tools available for this purpose, such as HxCFloppyEmulator (Windows), ADFLib (cross-platform), or other conversion utilities.
Thanks ChatGPT : This is not bad, but ADFLib doesn't support HFE files. :wink:
( this "user" is a ChatGPT driven bot, designed to spread and hide links on forums ) :
Screenshot at 2024-05-23 22-12-59.png (50.15 KiB) Viewed 36859 times
mamedio2
Post by mamedio2 »
Guys, I need a little help.
Some Amiga games stopped loading on Gotek, can anyone tell me what's happening?
I updated gotek
I downloaded ADFs of games that don't run and continue to not run.
Does anyone know what's going on?
