AKAI S5000 bad format sometimes
espritsonic
Post by espritsonic »
I have received my gotek with the hxc installed with the usb key.
because the s5000 can load wav audio file by PC dos disk, i use the software USB_Floppy_Manager_v140i
i format 100 disks
i load one floppy folder in the manager and put my wavs inside and finally save. i put on the sampler and select the track from 1 to 100 (floppy).
The problem is that the sounds are loaded by the sampler but sometimes not with a error message BAD FORMAT.
is a problem from the sampler or the bad configured usb key ?
Re: AKAI S5000 bad format sometimes
What do you mean by "sometimes" ?
