Just to make things slightly easier for those Googling for a solution to make Agilent 54641D (well, essentially this series of MSO models)
work with the SDHxCFESlim slimline units:
- add a 1kOhm resistor for R8 (next to the dipswitch)
- Subsequently have a look at viewtopic.php?f=25&t=1638&p=11450&hilit=agilent#p11450
The CFG file presented in that posting also makes the Agilent work
Now go and order a longer 26pin 1mm pitch FPC cable to connect the emulator to the scope. The original cable is too short
best 73,
Wilko
PA1WBU
