Screen Upsside down after firmware update
keluar
Post by keluar »
I was updating my Gotek drive to HxC firmware from flashfloppy. Since the update, my oled screen is upside down.
I have seen in you tube that adding display-type = oled-128x64-rotate in ff.cfg file fixes it on flashfloppy firmware.
OS there similar on for thr HxC firmware? It is annoying to see the screen upside down
Re: Screen Upsside down after firmware update
You have an U100LQD Gotek. Please use the firmware present in the U100LQD_Gotek_HxC_Firmware folder :
DrD
Post by DrD »
I have the same problem after updating firmware to latest version from U100LQD_Gotek_HxC_Firmware folder/Standard folder.
Is there any way to fix this please?
DrD wrote: Sun Jul 30, 2023 5:19 pm I have the same problem after updating firmware to latest version from U100LQD_Gotek_HxC_Firmware folder/Standard folder.
Yes : Since you don't have an U100LQD Gotek, use the non "U100LQD" firmware :
"Firmwares_Updates/Generic_Gotek/Standard_Firmware"
