Gotek E-34 in Akai S3000Xl
FTWLTG
Post by FTWLTG »
i recently bought a Akai S3000XL , it is working, i can record a sample and store it to the floppydisk.
i installed a Gotek with the 3 digit screen and flashed it using , but when it boots it shows and then it turns to E-34
am a little stuck in using the usb drive , what must be on the usb? config files? .img files?
i read that the S3000XL can not use wav files so i am a little stuck.
any help will be appreciated!
Re: Gotek E-34 in Akai S3000Xl
Get and install the HxC firmware first : https://hxc2001.com/store/
