Brother BAS311A embroidery machine and GOTEK SFRM72-FU
nerioj
Post by nerioj »
Hello, this is my first time in this forum.
I have a Floppy SFRM72-FU (F20129) and I need to validate the compatibility with a Brother embroidery machine, model BAS311A. I did multiple tests with the unit and its original firmware, changing the jumper settings without success, as well as using the file mode and the image mode on the USB memory. After researching in various forums, I found that with the firmware update it is possible to solve the compatibility with the Brother embroidery machine. As stated, I have two questions:
1-. Is the SFRM72-FU floppy in its version (F20129) compatible with the Brother BAS311A embroidery machine? If the answer is yes, what is the jumper configuration and what format should I give the USB memory?
2-. If the answer to point 1 is negative, will the firmware update solve the compatibility problem? If so, what method (serial, USB, flash) should I follow to install the HxC bootloader and subsequently update the firmware?
In advance, thank you for your attention and recommendations.
