Oric floppy support
AtomeX
Oric floppy support
Post by AtomeX »
I post you all my test, if you can find the solution:
1- I use a mastered Oricutron disk in dsk format, I can use on both emulator Oricutron/ClockSignal
2- I convert the dsk to hfe, I can use on emulator ClockSignal and Original Oric Atmos with Jasmin and Gotek HxC
3- I use the disk 2 and make a master with ClockSignal, I can use with ClockSignal and Original Oric Atmos with Jasmin and Gotek HxC
4- I convert the disk 3 to dsk and I can't use on both emulator
5- I use the disk 2 and make a master with Original Oric Atmos with Jasmin Drive, I can use with ClockSignal and Original Oric Atmos with Jasmin and Gotek HxC
6- I convert the disk 5 to dsk and I can use with ClockSignal only.
I hope this will help you, regards.
Cyril
Archive.zip
Disk
(173.87 KiB) Downloaded 471 times
