AKAI S2800
Duesentrieb
AKAI S2800
Post by Duesentrieb »
Hi There, :)
I got a Gotek SFRC922D (LED 3 digits display) and want to use it in an AKAI S2800
I connect my USB>RS232 Adapter Pin 2=RX to pin3 on the gotek and 3=TX>Pin2 Gotek , GRD>Pin6, 5V>Pin7 and bridged J3>3,3V power on, everything looks fine
NO USB STick conected yet
Serial Port COM8, Link is UP (in Serial Bridge SW)
but only bottom Line TX counting up slowly (now14)
I tried 3x an waited
Then it says "No response from device"
I reset Gotek by short P1RST and P6 (no reaction on Gotek SFRC922D)
Restart Serial Bridge SW
Same again...
Very Greatful for support!
regards Duesentrieb
Duesentrieb
Re: AKAI S2800
Perhaps Jumpers must be set? By default there is one on the second position S1. I tried so many things for hours, but nothing works, please help!
Thanks sooo much!!!
Re: AKAI S2800
I have already answered by email one day ago. Have you received it ?
You can use an RS232 adapter for this . You need a TTL serial adapter. or an USB A USB A cable :
https://hxc2001.com/docs/gotek-floppy-e ... ation.html
