I have an SCP file from 5.25" 360KB (48TPI) floppy drive and HxCFloppyEmulator.exe v2.1.24.1.
What works:
1. (click) Load -> (choose) SCP file
2. (click) Export -> (choose) IMG file (RAW sector file format)
3. IMG file is correctly exported
What does not work = produces corrupted files
2. (click) Disk Browser -> (change) file system type from 3.5" 720KB DSDD to 5.25" / 8" 360KB DSDD 300RPM FAT12
3. (click) Get Files -> (choose) Folder -> (click) OK
It this case, there is:
- major bug ~ few files are correct, but most of them have nulls instead of data
- minor bug ~ exported file have current date, but it would be nice to have date and time as is stored in the image
[bug?] HxCFloppyEmulator.exe corrupts file when exporting from SCP
- Right part is corrupted - nulls
- 02_right_part_corrupted.png (63.55 KiB) Viewed 48866 times
- 01_right_part_corrupted.png (59.61 KiB) Viewed 48866 times
Re: [bug?] HxCFloppyEmulator.exe corrupts file when exporting from SCP
Can you share this SCP image ? This may happen if the disk have some bad sectors.
Yes, here is the link with ZIP file, including SCP image and folder with correct files:
https://drive.google.com/uc?export=down ... T8UqMNCpXI
But the disk is correctly readable and also your tool can convert the SCP into proper RAW image.
Got it. There is an issue when loading the file. I will fix this.
Many thanks for fixes.
Any chance for fixing mentioned minor date & time issue?
Done :wylda wrote: Sun Aug 18, 2019 7:49 am Many thanks for fixes.![]()
Export of files from Disk Browser is fixed in v2.1.25.2, thank you!
But timestamps of exported files still remains unfixed. Any chance to fix it, so date and time remains the same as in the image files, please?
