SQ-80 AND GOTEK PROBLEMS
mindburner
Post by mindburner »
Hello all
I have got a gotek emulator with the oled display. My SQ80 will see the gotek but only after pressing the disk button on the SQ80 several times, usually there is a 'no disk' message. After another 10 button pushes it may get to loading a bank or it may fail.
jumper is set to S0
it's using .hfe files
I bough it from a seller, apparently pre-configured.
I also cannot format a blank slot. It tries but fails at sector 79
saving into an existing black slot also fails, with no disk
is there anything I can check
best regards
Alan
Re: SQ-80 AND GOTEK PROBLEMS
First , what can you read on the OLED screen without usb stick inserted ?
mindburner
hi many thanks for the reply.
It says
Flashfloppy
v2.11a
t:00.1
Ok then if you come here i suppose that you thought bought a Gotek HxC ? Unfortunately this is a counterfeit. Please report this seller if on ebay/amazon.
Fortunately this drive can be reflashed with a true HxC firmware with an usb stick. But you will have to get a license on this page :
https://hxc2001.com/store/
Then i will be able to provide support.
mindburner
ah right ok sorry. I wasn't aware of this at all. Yea it was on ebay.
seller seem totally legit but has been strangely quiet since I purchased the device
I have just obtained a licence from the link via PayPal
thanks again for this
mindburner wrote: Mon Jul 22, 2019 5:40 pm ah right ok sorry. I wasn't aware of this at all. Yea it was on ebay.
I just send you the procedure + the files.
mindburner
after registering I got a download link with instructions on how to flash the device.
I have a FTDI232 adapter, not sure if this is ok
connected it up but just get 'link is UP' message
checking connections.... and will try the reset trick
mindburner wrote: Mon Jul 22, 2019 6:37 pm after registering I got a download link with instructions on how to flash the device.
ah ok. In fact i sent to you the files to avoid the ftdi adapter.
you can update with an usb stick. See the procedure in the zip i sent to you.
mindburner
ah I have updated the device with the serial adapter 100/100 in status.
now Done (o units left)
however the oled display is now completely dead with nothing at all, UPDATE, this is due to really bad soldering to the display, now resoldered
mindburner wrote: Mon Jul 22, 2019 7:28 pm ah I have updated the device with the serial adapter 100/100 in status.
ok , Now update to the latest firmware :
mindburner
I now get your website and v3.374 :D
also it seems to read all the sound file disk images, and they load 1st time!
the only thing is the file numbers are missing, but maybe I can change this in the config
this is great
thank you
mindburner wrote: Mon Jul 22, 2019 7:58 pm I now get your website and v3.374 :D
this is great
thank you
Perfect ! :D
(About the file numbers i suppose that you are directly browsing the files on the stick ? In this mode there is no file numbering).
mindburner
hi yes directly browsing. I may just renumber the files so I no how far away from [..} I am
is there a way to put the oled display to sleep after a while
i'm sure these things exist, I just wasn't sure if they were accessed on the GOTEK or in the config file
thanks
mindburner wrote: Tue Jul 23, 2019 9:35 pm hi yes directly browsing. I may just renumber the files so I no how far away from [..} I am
thanks
The oled brightness should reduce after some seconds. This this is not the case ?
mindburner
Got did before I flashed it again. Now it's constantly on.
