Oberheim DPX1
s219800
Oberheim DPX1
Post by s219800 »
Hello, I am trying to set up a gotek emulator usb stick with the Oberheim DPX1
I didn't find any entry for it on the quickstart floppy, any chance I could recover a .cfg file for it?
also, will my Emulator II images work on it if in .hfe format?
any advice would be appreciated, thanks
Re: Oberheim DPX1
s219800 wrote: Mon Feb 25, 2019 12:35 pm Hello, I am trying to set up a gotek emulator usb stick with the Oberheim DPX1
Which image do you want ?
s219800 wrote: Mon Feb 25, 2019 12:35 pm also, will my Emulator II images work on it if in .hfe format?
They should, if you connect the emulator on the 5"1/4 floppy connector.
s219800
Re: Oberheim DPX1
Post by s219800 »
Hello Jeff;
I'd really like the indexed mode .cfg files and necessary files (plus some empty floppy images if possible) that the DPX would need in order to work on the 3.5 bay.
Maybe I could also ask you for the Korg DSS1 .cfg files and necessary files (plus some empty floppy images if possible) for the indexed mode, since the only ones I could find were for the normal mode and the gotek does not have an LCD screen on it.
As for the EII files, I will need to mount a second gotek on the 5'' 1/4 bay then.
Thanks for the help and the great customer support service you provide :)
Re: Oberheim DPX1
s219800 wrote: Mon Mar 04, 2019 1:59 pm Hello Jeff;
i think that you can take any HFE from shugart machines and format the images with the DPX.
s219800 wrote: Mon Mar 04, 2019 1:59 pm Maybe I could also ask you for the Korg DSS1 .cfg files and necessary files (plus some empty floppy images if possible) for the indexed mode, since the only ones I could find were for the normal mode and the gotek does not have an LCD screen on it.
You can find different disks images in this archive :
