Multiple file conversion
Gryzor
Post by Gryzor »
Hello!
A couple of days ago I ordered the SD version and, waiting for it to arrive, I thought I'd play with the software.
To my amazement, I saw that it only supports conversion of single files? Am I correct in that?
If this is so, then it's unbelievably awkward. Since I want to use it to dump big collections of games onto SD cards, doing it on single-file basis is simply not doable... can a mass-conversion tool be added?
Themis
PS a guide for the software would be useful, too :)
Re: Multiple file conversion
Gryzor wrote:Hello!
Themis
No, the mass-conversion tool is already there since a moment : you have the "batch converting" tool in software. (button convert...)
Gryzor
Post by Gryzor »
Ahhh I didn't see that because I thought you press this just to execute the conversion... grrrrrrrreat!!!!
Btw, this shows there's a need for a user guide of some sort :)
Thanks for pointing it out!!!
