Blup !
Hi !
I would like confirmation :
Connect a Hxc card (or gotek no mater) on the DIN 14 pin connectors to have a Second Floppy on Atari ST(F) and E
I think, no probleme to do this, just need to build cable, no need chipset like 74ls.
Is they are any body confirm this ?
And I would like to 'Swap' Drive A <>B, so for use External Hxc in 'A' and so, boot on it.
I think, to do this I need some modification IN the Atari and not in the 'external cable'
Same, Is they are any body confirm this ?
thks a lot
Atari ST + HXC External connected
Re: Atari ST + HXC External connected
Gotek + Hxc Firmware (Jumper in S0)
Connected in external with 14 Din
tested : Work
Original ATari Floppy in internal : A
and
External gotek+hxc fir in external : B, connected with cable
See here the pinout info :
http://atariage.com/forums/uploads/mont ... 613198.png
tested : Work
and
You can add a switch to swap drives... most mods require bending pins of YM or cutting tracks, but there are jumpers on board to use.
On STF you have W2 and on STE W300. These route either DS1 (2-3) or DS0 (1-2) signal to pin 5 of external floppy connector. The other jumper of your interest is the one on the internal Epson floppy drive. Here you have jumpers for DS0 (default) and DS1. They also have one common pin. So all you need is a 2-circuit (rails) ON-ON switch, to cross-switch the PIN5 signal to be DS1 or DS0, and on the same time the internal drive to react on DS0 or DS1 signal. Great place for a miniature push-switch is above the cartridge connector in a space between cover and shielding.
Second switch is a TOS switch (1.62/2.06 as I have an STE).
P.S.
This DIN-14 is really hard to find...
P.S.
