Batch script for making bulk empty/blank images. Included Inside! Great for Index mode
Prax
Post by Prax »
I created a simple batch program that will duplicate files on the fly. This is good for people using index mode primarily that wishes to create several blank/empty images quickly.
Just copy the contents below to notepad with the filename "duplicator.bat" and save (Also attached to this post.) Place a template HFE file in the same directory and just double click the batch file. The default is 100 copies of BLANK.HFE filename to DSKA0000.HFE ~ DSKA0099.HFE.
You can manually customize the defaults in the script or use command-line parameters to change the copy amount and/or template filename.
Such as "Duplicator.bat 20" to create 20 copies of BLANK.HFE or "Duplicator.bat 10 BLANKDOS.HFE" to create 10 copies of BLANKDOS.HFE
@echo off
CLS
setlocal EnableDelayedExpansion
REM ----------------------------------------------
REM These are defaults. Allows the batch file to be run directly without command-line parameters.
set DefaultSource=BLANK.HFE
set DefaultCount=100
set Filename=DSKA
set Padding=0000
set Extension=HFE
echo  FILE DUPLICATOR v1.0 by Prax (HxC Floppy Emulator Forums) https://hxc2001.com/floppy/forum/
IF "%1"=="" (
     SET count=%DefaultCount%
) ELSE (
     SET count=%1
IF "%2"=="" (
     SET Source=%DefaultSource%
) ELSE (
     SET Source=%2
REM The count before subtracting 1
set "absoluteCount=%count%"
set /a count-=1
set "leadingZeros=%Padding%%count%"
echo -------------------------------------------------------------------------------------------
echo  SOURCE FILENAME..: %Source%
echo  NUMBER TO COPY...: %absoluteCount%
echo  FILE FORMAT......: %Filename%%Padding%.%Extension% ~ %Filename%!leadingZeros:~-4!.%Extension%
echo  SYNTAX: DUPLICATOR[.BAT] [1~9999 (Default: %DefaultCount%)] [SOURCE_FILENAME (Default: %DefaultSource%)]
echo  NOTE: Existing files will be skipped.
SET /P AREYOUSURE=Are you sure (Y/[N])?
IF /I "%AREYOUSURE%" NEQ "Y" GOTO END
:START
for /L %%i in (0, 1, %count%) do (
     set "leadingZeros=%Padding%%%i"
     if exist %Filename%!leadingZeros:~-4!.%Extension% (
          echo [SKIP] %Filename%!leadingZeros:~-4!.%Extension% Exists.
     ) else (
          copy %Source% %Filename%!leadingZeros:~-4!.%Extension% >NUL
          echo [COPY] %Filename%!leadingZeros:~-4!.%Extension% Created.
echo  DONE!
pause
exit
:END
echo  ABORTED
pause
exit
duplicator.zip
(902 Bytes) Downloaded 662 times
