Yamaha TX16W + Gotek USB HxC *Works*
teevee
Post by teevee »
I just installed a Gotek USB in my Yamaha TX16W and it works brilliant together.
Jumper = S0 and the floppy cable is reverse.
***Note***
It would be cool to have the predefined format added to the emulator software ..Jeff ;)
mondo1976
Re: Yamaha TX16W + Gotek USB HxC *Works*
Post by mondo1976 »
What do you mean "format"? The disk format is straight DOS.
The interface type is Amiga (Generic only partially works) which can be set in the configuration file to apply to all HFEs on the drive or just use this premade configuration:
https://hxc2001.com/floppy/forum/download/file.php?id=896
teevee wrote:I just installed a Gotek USB in my Yamaha TX16W and it works brilliant together.
***Note***
Can you post it here ?
