ERROR: Can't open HXCSDFE.CFG - FW v3.0.8.2a - FSel v1.45a
h3nk
Post by h3nk »
On the Amiga1200 I got the following Error:
ERROR: Can't open HXCSDFE.CFG !
FW v3.0.8.2a
FSel v1.45a
The files on the stick are:
AUTOBOOT.HFE
HXCSDFE.CFG
HXCFEUSB_HFE_V3_0_8_2a.upd
Re: ERROR: Can't open HXCSDFE.CFG - FW v3.0.8.2a - FSel v1.4
h3nk wrote:On the Amiga1200 I got the following Error:
FW v3.0.8.2a
FSel v1.45a
AUTOBOOT.HFE
HXCSDFE.CFG
Could you make an image of your usb stick, zip it, and copy it to my ftp server (i will send you the login/pass) ?
http://www.osforensics.com/tools/write-usb-images.html ("Create image from USB drive" function)
I need it to debug the autoboot.hfe
h3nk
Post by h3nk »
sure just send me the usr/pass
tried another smaller stick - now it works fine
thanks!
thanks!
Anyway still interested by the bigger stick disk image...
h3nk
Post by h3nk »
imaging in progress... 30.01GB
update: imaging failed at 20% - i guess the stick is broken :?
0.03s - Adding eligible USB Drive [General USB Flash Disk ] to list.
0.05s - Ready...
34.70s - File F:\Downloads\big-stick-h3nk.bin selected.
45.78s - Selected - Disk 4 (General USB Flash Disk )
48.17s - Created 1 Create Threads. Imaging Starting Soon...
48.67s - Create image called on General USB Flash Disk (Disk 4)
48.67s - Creating image F:\Downloads\big-stick-h3nk.bin from General USB Flash Disk (Disk 4)
483.19s - Error: Failed to read from \\.\PhysicalDrive4 at offset 5251268608 (0x39000000).
h3nk wrote:imaging in progress... 30.01GB
0.05s - Ready...
even if you have a partial bin file, send me it.
