Ok, so I actually have one DSS-1, and two DSM-1 units.
Do I go with the Lotharek SD FB Floppy Drive Emulator (http://lotharek.pl/product.php?pid=121) for both, or some other?
Along with that, do I go with the Omniflop images (http://glenstegner.com/dss1/disk_omniflop.htm), ...
... or CopyQM file images, or some other (http://glenstegner.com/dss1/disk.htm)?
Finally, did i read correctly, flat cable, set jumpers to drive 0?
Got both a DSS-1 and DSM-1, which drive(s) to buy?
deanpeters
Re: Got both a DSS-1 and DSM-1, which drive(s) to buy?
I have the FB model.
I use CopyQM.
Drive A - ID0.
Good Luck.
I use CopyQM.
Drive A - ID0.
Good Luck.
deanpeters
Thanks for the tip. Just bought 3 of the FB models.
If it works, I'll sell one of the DSM-1's and call it even!
kreeper_6 wrote:I have the FB model.
I use CopyQM.
Drive A - ID0.
Good Luck.
