sfr1m44-u100 Gotek
tombe
sfr1m44-u100 Gotek
Post by tombe »
Hi everyone,
can anyone explain me on which machines etc... I can use sfr1m44-u100 updated version?
all I could find is description regarding this model like below;
Description:
100% Brand new, never used
Housing Material: ABS
Color: Gray
Model: SFR1M44-U100
Use normal USB flash drive as the medium for transfer design.
34pin floppy driver interface, 5V DC power supply, easy to install.
Capacity: 1.44MB 2HD Cylinders: 80 Tracks: 160 Sectors/Track: 18 Bytes/Sector: 512 Data
Transfer rate: 500 kbps Encoding method: MFM.
1000pcs partitions in USB flash drive can be used.
Built-in self-format function. (read relevant documents to use this function)
Not Support Jumpers
Floppy driver with below function needed:
Floppy driver with 34pin interface,and 5V DC power plug
Use 2HD flpppy disk with 1.44MB capacity
Format of disk : Cylinders: 80 Tracks: 160 Sectors/Track: 18 Bytes/Sector: 512 Date
Suitable for industrial control equipment
Panel:
8 segment numbers: represent partitions number
Green led: status of read and write operation
USB port: connect USB flash drive
Button:
Left button used to rise ten-digit, right botton used to rise single-digit
Press 2 button together to rise hundred-digit
Operation :
Format USB flash drive
Use built-in self-format function to format USB flash drive into 1000pcs
partitions.
Use software in CD format USB flash drive under WINDOWS XP/2000, into 000-099
100pcs partitions.
Install an emulator on computer, and format every partitions by operate
driver A:.
use emulator UFA1M44-100, plug USB flash drive on it,connect to computer, it
will recognized as removabe driver A: or B: under WINDOWS XP/2000/7, format
every partitions.
UFA1M44-100 also built in self-format function.
Read and write data.
Install emulator on machine
Install emulator on computer
Connect USB flash drive on computer, read and write data directory by
software, under WINDOWS XP/2000
Use emulator UFA1M44-100, plug usb flash drive on it, connect to computer,
read and write data under WINDOWS XP/2000/7
Jumper setting:
J5:---
JA:---
JC:---
JB:---
S0:Driver select 0
S1:Driver select 1
MO:Motor
