Amstrad CPC floppy cable
cpharlok
Post by cpharlok »
HI!
Just got my new HxC unit from Peter (thanks!) and I want to use it with a CPC 6128. Do you know how can I make the cable that goes from the HxC to the CPC (floppy link)? I have a 3.5, 34 pins PC one ready. I have been searching around the forum and websites but I am still unsure how to do it.
Thanks a million!
Re: Amstrad CPC floppy cable
cpharlok wrote:HI!
Thanks a million!
external or internal ?
cpharlok
Post by cpharlok »
Internal, I just want to replace the CPC fdd with the HxC
cpharlok wrote:Internal, I just want to replace the CPC fdd with the HxC
in this case you need to buid a 26pin to 34pins adapter. are you able to make a small pcb to do this ?
cpharlok
Post by cpharlok »
Mmm.... I cant build a PCB, can I use a blank pcb?
(Like this one: http://rsk.imageg.net/graphics/product_ ... 99w345.jpg )
CrazyIcecap
Post by CrazyIcecap »
Here are some infos, but in german. There's a picture of the connections for the drive.
http://www.cpc-forum.de/phpbb/viewtopic.php?t=582
CPCWiki has a lot of schematics:
http://cpcwiki.eu/index.php/Technical_documentation
cpharlok wrote:Mmm.... I cant build a PCB, can I use a blank pcb?
yes
schematic of the cable / pcb :
CrazyIcecap
Values for the resistors?
CrazyIcecap wrote:Values for the resistors?
it's some straps, so 0 ohms.
cpharlok
Post by cpharlok »
Excellent! I will build it and post the results :)
Thanks Jeff and CrazyIcecap :D
cpharlok wrote:Excellent! I will build it and post the results :)
Note: with the HxC Floppy Emulator you need only the strap R4, others are not populated.
izham_gb94
Amstrad CPC --external-- floppy cable
Post by izham_gb94 »
Hello everyone, and thank you very much for this device as incredible:
I'm new to this forum.
I do not speak English, this is a translation and I apologize for errors.
I want to connect my HxC Floppy Emulator on an Amstrad 6128, at the rear connector (external).
I have seen these messages in the schema (thanks Jeff) for an internal connection, but I do not know how to connect in the back.
Please, can any of you give a little help?.
Thanks and best regards.
Re: Amstrad CPC --external-- floppy cable
izham_gb94 wrote:Hello everyone, and thank you very much for this device as incredible:
here a picture of the external connection:
izham_gb94
Hello again:
Jeff, thank you very much for your response and for the images ... very descriptive.
I'll do some tests on these days.
izham_gb94
Hello again:
Sorry, I also post this message anywhere else wrong.
Sorry.
