Is possible adapt the hxc rom to use it in plus series cartridge?
I mean for example instead of have f1basic f2 burning rubber. F1 basic fx2 hxf rom. For the people don't have external rom devices Witouth need of buying new hardware.
I try it, but it nor appears work don't read the fdd from cartridge.
Hxc rom working in plus cartridge is posible?.
Re: Hxc rom working in plus cartridge is posible?.
I have created semisucesfully a cartridge with hxc rom and c4cpc loader embebed.
The idea was put the modified os to execute from c4cpc via jumper when computer is switch on. Then reusing the |jeux |juego from burning rubber to hxc and c4cpcloader
. So always can be accessed witouth hardware ram expansion.
It works but it appears a strange secondary thing.
When i reset hxc instead of go to basic or burning rubber menu he go the c4cpcloader embebed in the cartridge.
I think because it need to be reset instead of return to basic
. As the os is the c4cpc.
In case that anyone if interested, at finish i made a compilation cartridge to use with the 6128+.
It included:
-burning rubber pached(acelerate brake in the buttons 1 ,2 by default)
-Hxc floppy emulator manager(v3). With add options to tell It search in a or b when call It.
-c4cpc cartridge loader
Symbos 2.2
-future os last versión.
-cp/m with 9 extra rom expansions.
All in 512k cartridge witouth needed an external rom hardware.
Spanish, french,english,german versions, with amstrad amsdos,parados and firm 3.15 options.
https://mega.nz/#!B9wQXT4S!H2gA0cOFPN-Z ... 34-IOTA3RY
It included:
Symbos 2.2
