Bad file in larry's DSS1 library
RaRelis
Post by RaRelis »
larry has a bad file KORG-KSDU-001R / LB / Grand Piano and more Revised is not working to well. when you hold a note down it repeat's. I was wondering if you have a way to fix that problem it's the only file that dose that. That happens from file 1-9 and then it stops. I downloaded softwear update ver. HXCFE V1 8 2 40.UPD and the problem is still their. :?
Re: Bad file in larry's DSS1 library
probably a corrupted image...
RaRelis
Post by RaRelis »
I though the image was corrupt. Is their away to reach Larry , the email address on the web sit doesn't work. That grand piano image has the best sounds. :(
RaRelis
Post by RaRelis »
Jeff - Is their away to reach Larry ? The email address on the web sit doesn't work. That grand piano image has the best sounds and I would like to fix that image.
RaRelis wrote:Jeff - Is their away to reach Larry ? The email address on the web sit doesn't work. That grand piano image has the best sounds and I would like to fix that image.
Sorry i don't know.
