Two drives simultaneously with a only Gotek (AtariST-PC98)
eldelcairo
Post by eldelcairo »
I got a 3 digits Gotek for use on Atari ST and use also on PC-8801 and PC-9801/21. I want to know if it's possible to use A: B: drive "simultaneously" with only one device with Jeff's firmware, or do I need two devices Gotek for drive A and B?
In the boot Selector program for Atari ST mentions a jumper.
I attached photo
Thanks in advance.
mikeyp
Re: Two drives simultaneously with a only Gotek (AtariST-PC9
Post by mikeyp »
The gotek only supports one drive. A or B. You will need 2 physical drives with different jumper settings if you want to emulate both drives.
