I2C LCD Screen display not working with Gotek & Atari ST
mcSDHXC
Post by mcSDHXC »
Hi.
IC2 screen is illuminated but no characters are displayed. Gotek works perfectly.
Setup:
Atari STFM
Gotek with HxC Firmware version: 3.0.6.2a
I2C: http://www.ebay.co.uk/itm/161200022257? ... EBIDX%3AIT
Resistors (4.7K Ohm): http://www.ebay.co.uk/itm/281273174412? ... EBIDX%3AIT
Connected as per firmware notes:
SCL & SDA to J7 - both with 4.7 K Ohm resistors in line (tried without resistors with same result)
VCC & GND to J7
AUTOBOOT.HFE & HXCSDFE.CFG from SDCard_HxC_Floppy_Emulator_Manager\SDCard_HxC_Floppy_Emulator_Manager\Atari_ST installedf to root of SD card
Slots 1-10 filled with .st games files. Gotek Up/down buttons select games and they play OK.
Images here: https://drive.google.com/folderview?id= ... sp=sharing
Paradoxic
Re: I2C LCD Screen display not working with Gotek & Atari ST
Post by Paradoxic »
Resistors need to be "pull-up" connected from SCL to Vcc and from SDA to Vcc
(with SCL SDA connected to J7)
mcSDHXC
Post by mcSDHXC »
Paradoxic wrote:Resistors need to be "pull-up" connected from SCL to Vcc and from SDA to Vcc
So, I have removed the inline resistors from SCL and SDA and replaced them with 1 resistor going from SCL to VCC and 1 from SDA to VCC.
The result is still the same - the screen powers up but nothing is displayed.
mcSDHXC
Post by mcSDHXC »
Success! The pot on the back of the screen needed adjusting. All working now.
Thanks for your help.
Paradoxic
Post by Paradoxic »
Have fun :)
