blank hfe image for emax
does anyone have a blank hfe image file with os 3.2 so i can save my samples on my HXc drive on my Emax 1000?
Re: blank hfe image for emax
Have you checked out the EMAX related content in here?
yea thanks for the tip but doesn't seem to be a blank disc image in there
I think the Emax_Bios_Disc.hfe has the OS on it as you requested. You should be able to create a copy, use this in HxC and then format it from the EMAX? Then it should be an empty disk.
