Hi everybody,
Before the release of Windows 10, Mu PC is today under build 10240 of the next Microsoft OS (64 bits version).
But, today, I tried to put files on my HxC (SD) with HxCFloppyEmulator 2.0.26.0 and each time I tried to drag & drop files, it was impossible, just the "forbidden sign" on the file browser.
Do someone else try this feature under Windows 10 ?
Thank you.
HxC software ok with Windows 10 ?
Re: HxC software ok with Windows 10 ?
Last i tried this worked, but i will retry it ASAP.
Have you tried to start the hxc software as root ?
huggyone76
Yes, I tried the software as root.
I tried yesterday evening to run the HxC (the USB version yesterday) and I wasn't able to drag and drop .st or .msa files to the software, always the same forbidden sign.
I had to load files from the menu and everything worked well.
I'll re-install Windows 10 from zero as soon as I'll have the final version, perhaps the problem comes from Windows 10 itself that I installed above Windows 8.1 ?
