[Gotek] IPF to HFE Conversion Problem
xadox
Post by xadox »
I am using the Gotek with v3.0.3.1a in an Amiga 500.
I have converted some Amiga IPF files to HFE. Somehow the converted HFE files are not working right at all.
For example Rick Dangerous 2 (Europe):
There is a level selecting screen in the game. Choosing a different level than one ends in loading problems. Or after finishing level 1 the level selecting screen is showing again.
I am using the default HXCSDFE.CFG.
Re: [Gotek] IPF to HFE Conversion Problem
Not a surprise ! You will have to wait for the HFE format rev 2 support :)
AW99
Post by AW99 »
One question i have here, but for normal HxC-hardware not Gotek.
For adf`s it is recommended to try the image first with normal hfe format and only when this dont work, to use "hfe rev 2".
How is it for ipf`s? Is there also recommended to try first normal hfe or is here "hfe rev 2" the best for the most images?
xadox
Post by xadox »
Do I have to switch the HFE file Interfacemode from Auto to Amiga before conversion?
no
AW99 wrote:One question i have here, but for normal HxC-hardware not Gotek.
yes, rev 2 is better of the ipf.
xadox
Post by xadox »
Thx.
MrX_Cuci
Post by MrX_Cuci »
So I need to use HFE rev2 for IPF when I batch conevert, also for Gotek drive? What CAPSimg.dll do I use? The latest form the Softpres website is 5.1 (32 or 64bit?)
Can there anything be done to use it the IPF format natively, for example by using the Amiga version of CAPSImg?
xadox
Post by xadox »
HFE v2 is currently not supported by the Gotek on Amiga, I think.
xadox
Post by xadox »
Is there already any news in HFE v2 support?
hqqns
Post by hqqns »
Jeff wrote:Not a surprise ! You will have to wait for the HFE format rev 2 support :)
xadox wrote:Is there already any news in HFE v2 support?
It's been more than half a year, any update ?
cedric731
Post by cedric731 »
Hello Jeff,
Any news about HFE V2 for the gotek?
turrican9
Post by turrican9 »
Hello, I also wonder if the HFE V2 support will be implemented in the firmware?
cedric731
Post by cedric731 »
Post subject: Re: [Gotek] IPF to HFE Conversion ProblemPostPosted: Wed Jun 24, 2015 10:59 pm
@Jeff : any news about this development?
rev 3 incoming ! :wink:
