SD FB Floppy Drive Emulator (BLACK CASE) doesn't fit in 3.5'
geosiou
Post by geosiou »
Since I've seen this recently, I have to add that the housing of my SD FB Floppy Drive Emulator - BLACK CASES Rev F does NOT fit in my 3.5'' case, as well!!
I've measured a real floppy drive which fits and it is 10.1cm. My SD FB Floppy Drive Emulator - BLACK CASE Rev F is actually 10.27cm and there is not a way to put it in.
I bought the cased emulator only to be able to intall it inside the case!
I've read that Lotharek sent a replacement with perfect fit before and I need it too please.
How can that be arranged?
Thank you in advance.
George.
Re: SD FB Floppy Drive Emulator (BLACK CASE) doesn't fit in
First : When and Where did you bought your emulator and into which system are you trying to use it ?
geosiou
Post by geosiou »
I bought it directly from http://lotharek.pl in 18 March 2014, via PayPal (Transaction ID: 6UX35879Y8671134V).
I'm using it with a Spectrum and Plus D interface very successfully.
I have a Dual 3.5'' Floppy case but the SD FB Floppy Drive Emulator (BLACK CASE) doesn't fit in because of its width...
geosiou wrote:I bought it directly from http://lotharek.pl in 18 March 2014, via PayPal (Transaction ID: 6UX35879Y8671134V).
Ok. i have pointed this thread to Lotharek.
geosiou
Post by geosiou »
Thank you very much Jeff! It is a pity having the emulator bare and out of the case... Up to now I had to copy a vast number of disks and I was concentrated to this job. But now I would like to make my setup pretty as well, by removing one floppy drive from the dual case and putting the cased emulator inside, together with the other floppy drive. That was my original thought and that's why I bought the cased emulator...
geosiou
Post by geosiou »
Sorry Jeff for bothering you again, but I have no news from Lotharek yet...
lotharek
Post by lotharek »
sd f dimensions are described here : http://lotharek.pl/zasoby/produkty/120/pliki/tacka.pdf
just few weeks ago, i have reduced the size to 101,3 (painted version) mm and added threats at fiting holes.
Please, contact me using CONTACT BUTTON http://lotharek.pl/contact.php - SUBJECT -- OTHER SUBJECT
..... Atari Roxxx !!!
lotharek
Post by lotharek »
SIDE THREADS - bottom in next delivery of cases will be introduced.
geosiou
Post by geosiou »
Dear Lotharek,
The slimmer case replacement you sent me fits perfectly well!!!
Thank you for everything!!!
George.
