ATARI 1040STFM NO FLOPPY SHOWN AT TOS DESKTOP
gorgos10
Post by gorgos10 »
hallo
i connected hxc cased model (as internal drive a jumper settings-not twisted cable connection) and floppy manager shows the list ok but after i press f7 and the hxc reboots with the game selected hfe or .st the desktop shows no drive just the desktop.i have disconnected the internal floppy cable connector and drive power and i have connected the internal floppy cable with an extension floppy cable from you and have given power from the internal power connector to the hxc.how is it possible that is detects the floppy manager (so i presume the cable connection is ok?)and not the a drive after the reboot?
p.s i tested the hxc with the amstrad cpc 6128 and it works ok.
so any ideas?
tos rom update maybe ?
Re: ATARI 1040STFM NO FLOPPY SHOWN AT TOS DESKTOP
What about the switch setting ?
gorgos10
Post by gorgos10 »
you mean drive?set as a:
st switch config from manual
what about the floppy led on the st. Still on under the TOS ?
gorgos10
Post by gorgos10 »
new condition
now it doesnt boot from autoboot manager. when i delete it it boots and shows 2 drives at tos but when i open them they dont open at first and then they show empty the drive folder and the drive led yes is on always.
look like that your st have some problems. Can you take a picture of your setup ? (a picture with the connection of the hxc to the ST + its jumper setting)
